Squeaky front suspension
(In Topic #220743)
New front suspension squeaks on bumps
Last edit: by TBigJohn
borednow said
That's handy then.
I was going to suggest vaseline.
Makes your shaft slippy and stops the squeaking![]()
Ian
I just thought I'd get it out and run a file over the end, OOUCH!
TBigJohn said
After a runabout, the squeak has gone, but I have a slight rattle on the drivers side. I think one of Briano's comments I found about Febi top bush inserts being too long might be the answer to that problem, as the sound seems to be coming from that area.
LOL…. When I bought a new set of upper mounts, I had the issue that the bushing that went between the mount and the nut to exceed the length a wee bit, so I filed it a wee bit, I was more concerned with the hammering of the washer by the action of the piston rod having more travel than it should. I also tend to pack them with Grease, so that they rotate freely, and the underside of the washer as well I also place a modicum of Axle grease on the spring perches.
A nifty little trick I learned is that if you use a Childrens Dosing Syringe (Given away freely at the Pharmacy's (Chemists?) here, you can fill them with Axle Grease Vaseline, and oils to shoot a small stream where you may need it. I have also been known to place a piece of small hose on the end to reach around things.
All because of one broken spring tail.
Back in the air she goes! I hate cars I do.
I suppose I could ghetto fix it, just crank up the music.
So if you can look at that with a flash light to see if you have shiny parts, or at the rotor edge, and make sure your anti-squeel springs are properly set, as well as your caliper bracket bolts are sufficiently tight.
Briano1234 said
A rotational tick can be that your brake shields are a tad bent. I had that, and near drove me buggers…
I thought that, but as I parked it the garage I heard a loud whine and running feet, it was my Mojo escaping down the drive, along the road, and onto a bus into town!
I'll give it a coat of looking at maybe Friday.
Sorry to hear about your Mojo, but Mojo isn't everything, I lost my mind once, and well, when I found it someone had folded it in half and then stomped that sucker flat.
Ha Ha , I know that schizzle well, the medics filled me with some very nice painkillers years back, cold turkey was a lady dog (swear filter got me!
TBigJohn said
Well, investigations have isolated a very faint squeak to the gearbox end (automatic ) of the long drive shaft, and only when the wheel is spun in a forward direction. I think I'll crank up the Fosgates![]()
Wouldn't hurt to Drain the Oil in the Diff, and replenish or at least top it off.
That'll be next week, the sun's shining!!
