Speedo cables - Mk1 Scirocco GTI RHD
(In Topic #228611)
I run a late 1981 Mk1 Scirocco GTI and the speedo gauge is bouncing around at low speeds - signs of a worn cable I'm told.
The Mk1 Sciroccos all ran with the older style cone dashboard/clocks set up so I'm hoping/assuming I'd need a cable as per 79-80 pre-facelift GTI.
The MK2 Scirocco has the clip on job - did they change Golfs at the facelift stage to the same or did they retain the twist on cable for all Mk1 Golfs?
If that's the case - is there is a source for twist on Mk1 GTI speedo cables?
Thanks in advance.
the Clip style on the speedo and the Screw cap on the tranny.
Does anybody have a pointer re source for earlier type Speedo cables then?
Possible.
http://www.vag24.de/Tachowelle-Scirocco-I-11l-NOS
