Reverse lights only work of gearstick in certain position ?
(In Topic #234652)
Got no reverse lights of of a sudden. Got powee going back to the light - auto electrician verified this.
Reverse lights flicker on and come on when I wiggle the gearstick (whilst in reverse) -
Its as if the signal is intermittent and needs to be just right
Auto elec reckons the gear rods need adjusting somehow - can this actually be done?!
Or is it likely to be the switch on the box - he didnt think so as we could make the reverse lights come on by wiggling the gearstick
Also the loom from the switch links onto the main loom and the connector can corrode.
Is the switch easy to change? Any guides about? Which switch did you buy?
The switch looks like this (check it's the right on?)
Lots of places sell them, this is the 1st one I found so shop around if needing a new switch.
https://www.ebay.co.uk/itm/363560300072?hash=item54a5e1ee28:g:e2IAAOSwOUphpmMY
Info on the reversing light switch.
Reverse Wiring
Pulls out and then new one slides back in? I presume a dodgy switch would cause it to only work if gearstick is in a certain position? There is a little bit of play in reverse only, side to side even though the rods are new
Could be someone has change the gearbox as later cars had a different revering light switch which only has 2 pins.
2 pin switch.
https://www.ebay.co.uk/itm/200824519873?hash=item2ec212fcc1:g:SdwAAOSwnDpaFTjw
Make sure the new seal if fitted correctly or you can get an oil leak.
New switch, you can email to check it's the right one for your car.
https://www.classic-vw.co.uk/gti-reverse-switch-with-mfa-191919823-mk1-golf-caddy-jetta-mk2-16142-p.asp
Chairman
I bought a new switch but didn't need to use it!! 🤬
Chairman
If the car hasn't had the linkage done it could be worn and sloppy, potentially affecting the reverse switches operation.
