Play in gearbox flange.
(In Topic #220544)
I have noticed a small oil leak from my gearbox flange seal which I replaced 30,000 miles ago and on closer inspection I seem to have up and down play when I grab hold of the drive shafts, there is also a little play and clonking when twisting/rotating the drive shafts by hand.
I also noticed today as I had the window open that at lower speeds 20-30 mph I can hear a click/tap noise when on light throttle, it goes away when accelerating or throttle off and slowing down, the faster I go the faster the clicking so it’s drive related.
Is it something I can do or is it a gearbox rebuild?
I did check over the gearbox when I put it in the car, new drive shaft seal, I had to swop the flanges over to 100mm as it was fitted with 90mm flanges, new input seal and bush, new thrust bearing, checked the push rod and fully synthetic oil so I know the basics of a gearbox but I’ve not ventured inside one….
Whats your thought…
Whats your thought…
Whats the gearbox code? VW modified post 82 gearboxes to reduce the symptoms you describe.
Gearbox code is where things get a little tricky….
It's. VW 020 6W gearbox which I think came out of a Monteago (I cant find much info online) but not 100% sure as it's 2nd hand to me, It had 90mm flanges and the bigger muilt funtion reversing light/up shift light socket, I've been driving with it for 3 years and 30,000 miles and no 2nd gear crunch, no oil leaks or the noise I'm now hearing..
sounds like you have play in the differential bearings, even early boxes without the extra tension spring setup shouldnt have enough play to ruin new flange seals.
my late mk2 gearbox had play in the flanges both wiggle and rotational lash. on drainign of oil it was metallic brown, and when stripped it was in a real sorry state
