New alloy wheels
(In Topic #207572)
Been given a set of Speedline Audi 80 alloy wheels in 4x108 with an ET 37
Now if I find a set of hubcentric adaptors they will stick out past the archs as iirc spacers of 20mm will make the ET 07.
Has anyone had or know of anyone who has alloy wheel bolt holes welded and reweld for correct fitment.
They won't fit with out spacers anyway as it's hitting the suspension strut/spring.
Pics of wheels at the bottom
Another question regarding the brakes.
It has a Mk2 master cylinder and servo but the brakes feel shocking, almost like there is no servo action, very small amount of movement when pumped and engine is started.
Would this be a symptom of not having some threads chopped of the brake bar behind? Have the feeling it's no benefit done, il be rebuilding another one but don't want to rebuild it and get the same feeling
Saab 93 diesel daily
with the brakes if the servo hadnt been cut down the brakes would be stuck on all the time, it sounds to me like the servo is dead or there is no vacuum feed to it. perhaps the non-return valve(s) on the servo line were installed the wrong way round, I've made that mistake before
