Mk1 Suspension Kit Advice
(In Topic #188104)
Hi
My car has FK Coilovers on at the moment and they have been on the car for a while. The previous owner had them wound really low and the spings were just floating around
Wound them up and the ride is still rock hard like there is no suspension at all. Im thinking of changing them for a set of shocks/lowering springs and was looking at the AP shocks & Spring Kits on Venom does anyone have any experience of these?
neil
neil
Hello bud,
Quite strangely I was just about to post the exact same question! I've got an '88 GTI cabby with the original suspension and its a bit tired to be honest, so I'm looking at some way of sharpening it up. I'm looking at shocks/springs rather than coilovers and I've been looking at the AP Sports kit. If you do decide to go for it I'd be really interested in hearing what you think of it. Would be great if anyone has already fitted this and could provide some opinion. I'm half tempted just to go for it, as I've been looking at various options for a while now.
I had a chat with Venom and they suggested the FK shocks and Springs Kits are slighly more complaint than the AP's
Hopefully someone who has them fitted will comment that way we can make a choice.
The FK coilovers i have fitted at the moment are so hard its ridiculous. It can be wound down really low so it looks great but its not good to drive on a regular.
The general view seems to be that unless you spend big money on coilovers the ride quality wont be good hence why im going for shocks and springs.
Id considered going for a set of factory shocks and putting lowering springs on them as well.
I'll update you on which way i go with it
Yeah, I've not really considered coilovers for that very reason. I was toying with the idea of rebuilding my suspension with lowering springs, but I'm leaning towards just buying a complete set up instead. Had a quick look on the Venom website - which FK set are you thinking of?
I have just put the AP Coilover kit, when wound down LOW…it is rock hard. Wound it back up to around 3 finger spaces between tyre and wheel arch, and it is slightly more forgiving.
I've been looking at the same thing, spring will not go as low but won't shake ya teeth out either haha..
Instagram Firemandan1
Motorsportworld are doing WEITEC DAMPER AND SPRINGS for around £ 280 (60mm)….also Venom do the AP for similar……………………. getting rid of the coilovers
supercharged999 said
Motorsportworld are doing WEITEC DAMPER AND SPRINGS for around £ 280 (60mm)….also Venom do the AP for similar……………………. getting rid of the coilovers![]()
Seems a good replacement, are you going for them ? ?
Just spoke to VENOM, and they said that i will get the same harsh ride from any spring /damper set up…….
I've had AP coilovers on for about 1200 miles now, they seem to be becoming a bit more forgiving!
What type of space do you have between tyre and wheel arch ??
Could maybe get a finger in! Not sure, off hand, how much further they could be wound down.
MY back end was like that (scraped on wheel arch)…now slightly higher (i feel like a bobbing dog now)….
Hi, I am wanting to revert back to springs and shocks also but am now totally confused. I bought the car with the coilovers and its a shocking ride. I was thinking of going back to standard setup but with Eiback springs to lower it 40mm alround. Any advice on this???
Standard shocks with the Eibach are probably the best option, i am going to go for the Weitec shock and spring combo...
Whats made your mind up on that system? How much is the kit etc?
Checkout MOTORSPORTWORLD…
Thats actually not a bad price, I was expecting more. I guess you have to replace the bump stops etc which is a cost ontop but there not a massive bill
Did not know that…where do you get them from ?
You can get it all from Heritage or Classic-VW but I am only guessing you will need to. I doubt I have much of the original suspension left at all
