Low - FARB touching chassis.
(In Topic #199089)
Are there any modified bars that can be bought that allow for lowering so much or is there a way of modifying anything without cutting notches out of the chassis?
This must be a known issue with workarounds due to the sheer number of people who lower their golfs!
thanks,
Craig
abfmk1 said
Just remove it.
Seriously?
1985 Cabriolet GL
stiffening up the shell is a separate issue, for that you would use strut braces upper, lower and rear. the rear is pretty stiff already with the big lump of steel between the towers, but the front is just as wobbly as the tintops. VW factory fitted a lower K shaped bar on the cab and scirocco
