Lifting a rabbit country style
(In Topic #220130)
Sent from my E6810 using Tapatalk
It prevented the Droopy or saggy rear-end when loaded.
Since I was using this Diesel Bunny as a work car, with about 300 lbs of load I bought a set and installed them.
I could put 3 adults in the car with out it sagging and it drove down the road just fine.
You may have to go with Coil overs or buy a new set of Golf Springs. If you haven't replaced the rears yet, then your in for a treat as they tend to rust weld the lower mounting bolt in to the rubber bushings sleeve, and I have had to use a sawz-all/hacksaw to cut the bolt free to allow the strut to drop.
Possibly going back with a pair of passat rear struts may work.
