Hydraulic clutch resevoir
(In Topic #203978)
https://vwheritage.mobi/GB/productDetails.cfm?iItemID=171934495
abfmk1 said
As long as the reservoir is higher than the clutch m/cylinder i see no reason you cannot use it, thats what its for, isnt it. Personally i like to keep them seperate.
That one does have the feature that the outlet for the clutch is higher than the brakes, thus if there was a leak in the clutch side the brakes would still work.
