How to identify which brake master cylinder?
(In Topic #186920)
As I'm nearly over the drama of changing the exhaust manifold gasket and while I'm waiting for the manifold flanges to be skimmed, I'm tackling the brakes.
the first issue I have is the pedal doesn't return whenever the brakes are pressed so I'm changing the master cylinder but I found about five different types so how do I determine which one I need?
They seem to be catagorised by the number of ports which i can count but also by the cylinder diameter so where is that measurment taken?
Also, if I get one with a larger diameter, will it mount on the servo and would it offer any improvement to overall brake performance?
the size is cast into the MC somewhere usually
