HAND BRAKE HELP
(In Topic #203564)
If this doesn't do it, then you're into removing the drum to do a manual adjustment. In theory there is an auto adjusting wedge but in practice they tend not to click down, so need manual adjusting. If your drums are worn you'll need to also remove the lip from the drum eg with a Dremel otherwise once adjusted you can't get the drum back on. And if you do force it on, you'll probably never get it off again!
