Gearbox overhaul
(In Topic #237125)
Fitting new s/h box - any advice
My '80 cabriolet has a whine in top gear and has recently developed a rumble which has not been solved with new drive shafts. I was lucky enough to pickup a complete '92 car for parts which has low miles and was running perfectly before a light front-end crash that bent the R/H chassis leg and wrote it off.
The 'new' gearbox is out, and I've cleaned it up. I was thinking new drive-shaft seals and input shaft seal, along with fresh oil, clutch and mounts, and maybe a linkage kit.
Is there anything else that I should do before I get stuck in and remove the old box to fit the new one?
I forgot, the car is a 1500GLS but with a later 1800 carb engine. The parts car is an 1800 GTI. Both have 5-speed boxes with 100mm cup driveshafts..
Thanks,
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
The only other thing I can think of replace the green tin-lid cover thingy on the end of the box if it looks at all rusty. You dont want it leaking oil after all your hard work.
Oh, and poss a new clutch cable if the existing ones worn/sticky
The green tin-lid-cover-thing you're referring to is plastic on this box (like on the other one) so corrosion shouldn't be a problem in the short term…
I'll get a new clutch cable too.
Thanks again,
Robin
see www.brokevw.com
The 90mm Axles fit in to 100mm Spindles, but the 100mm axles will not fit into the 90mm spindles.
So just swap the cups over.
The green Cap means it is a 5spd gearbox, and that you have to swap over the linkages and bits if your OEM was a 4spd.
Now I just have to find the time to work on it! There's an E30 BMW and a S123 Merc in the workshop at the moment
Robin
