Gearbox linkage
(In Topic #221760)
Sincerely , it's very easy , and everybody can do it.
The only point that can be difficult is adjusting the lever stem to the linkage system.
LIGHTER IS FASTER !!!
Replace 1 arm at a time and make a mark on positions of splined rods etc when taking things apart, you can get away with leaving the gear stick if not much play as that requires re setting in position or you lose gears….
Haynes manual has info on measurements if needed.
https://www.ebay.co.uk/itm/VW-GOLF-MK1-and-GTI-LINKAGE-KIT-C19/190302289038?epid=1227473557&hash=item2c4ee67c8e:g:X3AAAMXQwKdRdgiw
But it isn't that hard.
Start at page 3 if you don't need to re-bush the gear stick.
Gear Linkage Change (Page 1) - The Mk1 Golf Owners Club
