Gearbox issues 1st gear
(In Topic #184956)
Help !
i have lost first gear ! It's like it's not there anymore ?
I have the box out so it's not a worn linkage.
i have recently swapped the speedo cable as it had gone. On removing the cable I found that the drive had gone on holiday to costa del gearbox !
i was told there was no way of getting it out once it was in unless you spilt the box and tbh this is beyond my skills. I was also told that they were made of plastic for a reason and that it would just chew it up and there would be no problems. Ahem ! I have problems.
my question is this.
should I just put it back on and hope that it just chews what's left and first gear may become free ? Or take it and get it opened.
im thinking that part of it is blocking the route to first gear as everything else works as it should.
thanks in advance
if you split the box without changign any of the internals you're fine to rebuild it with a new gasket:
Welcome to BrokeVW.com
I now need another gearbox !
My question, can I use a mk2 gearbox
It's a 1989 convertable with an AX engine code.
If not where is the best place to get a reconditioned box ?
Engine code is EXO55578
Chassis is WVWZZZ15ZKKO33862
if 100mm then as above, plus piost-84 cabrio/scirocco gti. if 90mm then mk1 gti up to 1983, mk2 carb 1.6 or 1.8, 1.5-1.8 mk1 & cabrio/scirocco carb except for 1988 onwards 1.8 (accordign to etka anyway, some have said their post-88 1.8 carb still had 90mm flanges)
I had wondered after replacing a few parts and finding the date of 14,07,1989 on things like the seat foam which happens to be my birth day only in 1975.
Thanks again
