Gearbox inspection plug removal
(In Topic #235480)
See picture. How do I get this bigger out without damaging the thread or dropping bits inside the gearbox?
All I wanted to do was see the timing marks so I could check the ignition timing.
Early-1800 said
The black bit in the centre pulls up/out.
So I tried with that removed but couldn't see the timing marks, I had read you need to unscrew the surround to get a clear look at them - hence me trying to remove the white bit as well!
I had to violently remove mine and replace it with lashings of grease so it can more easily removed next time
Early-1800 said
think it was designed for some dealer service tool to be inserted into the hole (behave yourselves) and a better view is gained by removing it.
Fair enough - I'll give it another go tomorrow and order a replacement!
Yes they do unscrew but do often get stuck in there. If you have some sort of big bolt you can remove the black bit and fit the big bolt into the white part to unscrew it. If not then use a thicker bar instead of a screw driver to drift it around, the screw driver will just dig a hole in the plastic.
When fitting a new one I've found if you don't screw it all the way in, just to where it's stiff twisting it in by hand, then that's enough to hold it in place
https://www.ebay.co.uk/itm/284644355651?_trkparms=ispr%3D1&hash=item4246202e43:g:kPMAAOSwLoBiAj7E&amdata=enc%3AAQAGAAAA4PiuHDGh8CO33a%2BDmmsX4Dh2d5UMWt%2F89AUNYwmBSJuE7zfCo0WBxgMFflrYR8Jw5%2FB1xsU5vgVBwfTve%2BK59fKXsBdhm1JjezrCzs4%2Bqg7uX68d94BvftbnF57DbwqzRw%2B%2FveIArFJ59KYmlaB1ve6sdynujgGDeOPiKnogNCY3SewEY4YHSfmqYF8B%2FTF6%2FIUbAs4K1YbaUXLIbfXqb34PgOLZFHn%2BYcrzRhnG03bew5gWTEwOcaY%2F0IfguTUR7AXL1aGyCr%2FWWj9qdm1Lr0u2n7RL8ziQ3kGuGtMoHh3X%7Ctkp%3ABFBMhP2dhpRg
How-to-flush-your radiator | Volkswagen Owners Club Forum
then you have a large working area to grab with a wrench or vice-grips.
I had one that was so trashed that I just cut it out with a hand driven hack saw blade to replace it.
If you don't remove the white outer plug you can see the tru alignment of the timing finger to the flywheel.
going back I would wrap the thread of the new plug with teflon tape, and don't over tighten it snug works well.
