Front struts have vertical play?
(In Topic #234311)
The top nut inside the strut housing is as tight as it can go. I've seen you can buy these spacer washers - do I just need to put them under the struts top nut to pack it out?
https://www.ebay.co.uk/itm/Pair-MK1-Golf-Caddy-Scirocco-Suspension-Top-Mount-Bearing-Spacer-/124763444205?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Do I need any washers, etc, or will these spacers under the nut be fine?
For what it's worth, the suspension has no play under weight of the vehicle, but I don't like to imagine what'll happen if I hit a pothole with the play in the front struts!
Under the nut on the top mount, there should be a washer and a Bushing. This bushing can be to high and you will have a few MM of play, this bush should be no higher than the upper plate.
You can also beef up your mounts with 3m window weld or use a rubber oring to extend the life of the mount.
see
34 years ago to the day - January 9, 1982 | Page 4 | VW Vortex - Volkswagen Forum
page 4 post 77
