Floppy clutch cable
(In Topic #197711)
Life Member
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Life Member
When looking at the car;
The clutch should be routed from the bulk head, around the left had side of the engine (around / ontop the cam cover - i've seen both ways) it then should have a clip which is attached to either the second or 3rd rocker cover bolt, which the cable sits in (so it's parallel with the block at this point) it then should continue straight across towards the gear box, and then take a sharp bend to sit on that bracket, have a look at the attached photo
Also by the looks of things you're adjusting it to be loose, you want to get it in situ, undo the silver nut, twist the black plastic mushroom shaped thing (until your clutch cable sits level with the brake pedal with about 1.5-2" of travel before you start feeling the clutch pull) and then lock the metal nut against the plastic (not to tight though)
Hope that helps you mate!
Also if you haven't already, add the clutch plate fix, around £5 from GSF (as the cars were built for LHD, the bulk head wasn't reinforced on that side) and they're prone to pull through
Follow us on:
Follow us on:
Life Member
https://www.vwheritage.com/shop/171898152/bulkhead-repair-patch-for-clutch-cable-mk1-golf-jetta-sciro/?gclid=CKDevIq5kcYCFcXLtAodmRgAvA
Follow us on:
Follow us on:
Life Member
stumpymatt said
Thanks for that mate. I'll have a go at routing it better, but I'm not convinced! It is adjusted to be loose yes, because the arm didn't seem t have the power to pull t back, even if I stood the cable upright. It feels like there is no pressure from the clutch on the push rod?
Ah sorry I see what you mean, unfortunately my knowledge is limited to the cable haha, someone will come along an be able to help you though
Follow us on:
Follow us on:
most of the clutch release parts can be replaced and checked box in situ, but the release plate is on the clutch kit itself so you got to pull the gearbox off to look at that.
this site has some great info:
Welcome to BrokeVW.com
Life Member
stumpymatt said
Sooooo, yeahhhhh; found the problem…. namely me and my ignorance / rushing jobs…. thanks for all the advice though guys, i'd never have found out that I was the problem without it!
What was the problem Matt, what
Glad you got it sorted though, you don't really have time for problems do you
Follow us on:
Follow us on:
Life Member
stumpymatt said
I had it in my head that the 'slack' movement of the arm i.e. up to 9o'clock was the bit that was supposed to release the clutch. Not thinking that it was the past 9o'clock bit that released the clutch. So flaming obvious once I stood back and thought about it, but when i'm working on it in snatched 40 minutes here and there, I keep missing the obvious. I left the circlip off the speedo cable drive gear the other day; the drive gear fell off in the gearbox and I spent 2 hours fishing it out. I think I screamed every profanity in the book at it during that time!
Ah we all do things like that, especially in a rush!
Is that the little red / green (can't remember the colour) that drops in the top of the box, the ones that made of plastic with no plastic magent been invented yet?
Follow us on:
Follow us on:
