Drive trouble after hitting pot hole @ 10MPH
(In Topic #206796)
vw golf 1.5 auto gls
After hitting a pot hole with the f/n/s wheel the car has sounded horrible. the pothole was so deep the car grounded on the plate in front of the auto box & stopped dead. There is a knocking noise that matches the wheel speed. sometimes when in reverse the car will stop as if i've hit a wall. only time I've had this is when a driveshaft cv come off. cv's seem fine. I've jacked both wheels up & with the car in drive or reverse only the f/n/s wheel is powered. the o/s/f seems to coast round & can be stopped by hand. could it be the diff? never played with any gearbox before but up for the challenge.
Any ideas greatly received.
cheers in advance
Once you've found out the extent of the damage, you should be able to claim off the council or whoever are responsible for maintaining the roads, a pothole deep enough to damage a car is obviously unacceptable. Worth revisiting the scene and taking some pics with a ruler in the hole, etc and recording details for a possible subsequent claim.
Good idea about claiming. I will do that asap.
cheers again
I'd suggest driving the car forwards and backwards in tight turns, this normally reveals diff issues, I am thinking you might have cracked the casing - if so then its new gearbox time.
1st gear with full lock, no noise
I think the noise is when i get into 2nd or 3rd gear (only a 3 speed box).
Sent from my POT-LX1 using Tapatalk
