Confusing Ride Height/Camber Issue
(In Topic #244199)
Last edit: by 111Robin
1981 Golf CL 1.3
abfmk1 said
Are the bolts connecting strut to hub including camber bolts tight ?…
Yes, all tightened.
1981 Golf CL 1.3
typ_53b said
Have you fitted softer/longer springs than before? Assuming all your wishbone joints are secure, that could explain the difference from what you experienced before. It will likely take a few hundred miles for the new springs and bushes to settle to their natural position before you can make the final geometry adjustments.
I reused the original springs. I understand things settling in but this cyclic rising.falling of the front end is very strange.
1981 Golf CL 1.3
Early-1800 said
tighten up the wishbone bushes/bolts when its on the ground in its normal position
That's how I torqued up the bottom arms so there should be no undue stresses on the bushes.
1981 Golf CL 1.3
1981 Golf CL 1.3
typ_53b said
A small rise and fall doesn't serm too concerning but the noticeable camber shifts seem very strange. It sounds more like the sort of behaviour you would expect if a wishbone bush was completely missing, or perhaps far too soft?
You would think so but the bushes are new, correctly located and torqued under load. I'll go through everything again tomorrow incase I've missed something obvious.
1981 Golf CL 1.3
1981 Golf CL 1.3
typ_53b said
I'd always assumed the wishbones were free to rotate within the rear bushes, so they would find their own angle, but I may be wrong. The flat part of the bushes should presumably be clamped parallel to the floorpan
Yes they are. The bushes are a very tight fit on the arm, I'm assuming that they twist the rubber as the arm moves to provide some form of resistance but could be wrong. On later VWs I'm familiar with the bush and arm are hexagonal so that the bush twists but I'm not sure if the theory is the same for this early type.
1981 Golf CL 1.3
1981 Golf CL 1.3
Everything is fitted correctly and brand new apart from the springs. There is absolutely no corrosion, it is perfect and before I fitted the new parts it sat and drove with no issues at all. As the hub is fixed at the bottom by the control arm the wheel can only be tipping in at the top, for what reason I have no idea. The top mounts are new Febi and are correctly fitted. Why it cycles from negative camber to none is a complete mystery. Both sides are doing exactly the same too which is even more strange. All I can do is check underneath at both extremes to see if anything looks wrong.typ_53b said
I see what you mean - the difference in camber between the two photos looks incredible. This must surely be down to a massive amount of play somewhere in the lower strut or control arm. Are you certain all the joints are sound and bolts secure. If so, I am wondering if there could be a more sinister cause, eg flexing of the control arm mounts due to structural corrosion in the chassis.
1981 Golf CL 1.3
How tight are your axle nuts?
Briano1234 said
What does the top of the strut mount look like and what is the distance in the gap between the top steel plate and the rubber mount? Do you have the Bushing in the mount and is the upper washer fully seated against the steel plate or about .10 In space between them?
I can only confirm that the spacers are fitted and the nuts tightened down fully. I would say that the top mounts seemed to be quite loose in that they can be rocked a fair bit. I'm not sure if this is normal but they were assembled as per the old ones and the nuts tightened down fully onto the spacers. I think I'll remove the struts again to double check. When you mention the upper washer, is fully seated correct or should there be a .10 (inch ?) gap ?. I couldn't really see any way to go wrong with these but you have sewn the seeds of doubt now. If there is that much "rock" on the mounts this could be causing the strut to tip in excessively.
1981 Golf CL 1.3
