Cabbie Rear Brake Conversion to Disc (1982)
(In Topic #197912)
Website Manager
There were two methods of setting and controlling the rear bias, one fitted to the rear and spring loaded to the axle. The other was pro portioning valves screwed directly into the bottom of the master cylinder, which restricted the flow to the rear brakes. There were two types of these, one for rear disks (16V Scirocco) and the other for rear drums (mainly late model cabbies).
on my cabrio i binned those 2 valves and fitted mk2/3 brake pipe T pieces in their place, this helped me in 2 ways. first it gave me holes for my brake light switches and 2nd allowed me to bin the valves without having to redo the lines
if i was to do it again id convert to late cab/rocco pedal mounted switch setup
the mk2 servo/mc is a tried n tested upgrade
