Brake servo
(In Topic #224379)
Quick question
So the search continues for my upgrade and I may have found one from a 9 inch one from a Mk2 Jetta - presumably the Jetta is the same as the Golf one, can anyone confirm?
It's only got a 2 port master cylinder at the moment but presumably if it is the same can I just get a 4 port 22.2mm one for a golf and drop that on?
But regardless, has anyone fitted one from something else? I've been looking for a while now and there are lots on ebay that look similar and are a damn site cheaper (and newer) than Mk2 Golf ones that may be a source for the future…
Ive bought one from ( i think a clio 197/200) it has 4 mounting bolts and bolts on the same, it appears to accept the 22mm master cylinder and has a clevis fitting. Only fly in the ointment is its actually 10 inch and i think it will foul the plastic header tank. I just thought i would lift the h/t up slightly if there is room. Plus points are these are much newer than mk2 golf parts and it cost £20.. Maybe other sizes are available..
Is it 4 port for a mk1? I thought we only needed 2.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
it uses t pieces to go into 4 lines, so a 4 port is better.
Ah. Guess that gives me an excuse to buy a brand new one then. Cheers.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
