Brake Linkage Bearings
(In Topic #237293)
How to remove the bearings
I have tried pressing but it didn't budge (might have been too gentle).
Any ideas? Thanks in advance
80 Cabriolet GLi
Pack them with good Marine grade Grease and see how they feel.
When I have to press out bearings in the past, I supported the bearing and you have to remember if they are peaned in the bracket are they peaned on both sides? as you want to press them out in the direction of the pean marks.
So on the pean side I would use a socket that is a deep well as large as the diameter of the part holding the bearing so it has a place to leave from.
On the opposite side I would use a large "C" clamp and a socket the same size or slightly sammler than the outer race as the press point, then tighten the Screw. This usually worked for me on smaller bearing over the years.
But cleaning it would be the first thing, re-greasing it and checking it for play, as there is no way I would start this adventure without finding a replacement first in case ca-ca occurs.
