Bottom ball joint change for m.o.t
(In Topic #188915)
In any case, once it's free then you've three nuts/bolts holding it to the end of the wishbone
be sure to remove the bolt from the bearign carrier completly as the ball joint has a notch machined into it the bolt goes thru so it'll never come off otherwise
