Black diamond clutches any good?
(In Topic #205890)
Any help at all would be greatly appreciated!
paul_c said
There's nothing wrong with the standard clutch (I say standard, I mean the OEM upgrade to a 16V clutch/flywheel etc with the appropriate friction disc for your gearbox) they can handle the power no problems. So there's no point spending further money on a black diamond item.
Cheers Paul for the reply, so do you mean upgrade to a larger friction disc with the appropriate flywheel and pressure plate? I could upgrade to the 1.8 gti clutch with flywheel and pressure plate but I'm not sure it would be cheaper than the upgraded 1.6 clutch
the sachs kits use the same pressure plate for both 8v and 16v kits. and i have one currently takign 149 torques and 166bhp in my mk2 abf no problem
rubjonny said
just buy a std sdachs clutch kit, it'll be fine. if you cant find a 1.6 200mm one use a 1.8 8v 210mm and swap the flywheel to suit.
paul_c said
My old Mk1 Golf GTI ran fine with a standard clutch, and achieved 14.15secs on the quarter mile. I also used a datalogger and there was no issues with clutch slip at the launch. I never had it dyno'd in its fastest state of tune (I did have it dyno'd once, then undertook a bunch of tweaks) but I estimate it was around 160-170bhp. Being a 16V, it will have had slightly less torque than an 8V though :-)
Thanks lads for the help! I just went and bought a standard 200mm sachs clutch kit, it was only 50 quid so if it slips I won't be too bothered about having to buy an upgrade as it's worth a shot! Cheers again, I'll try and remember to upload a video when it's eventually complete hahaha
