Black Diamond Clutch kit for 1.8 GTi
(In Topic #203190)
Has anyone fitted a Black Diamond clutch to a 1.8 Gti - Were the benefits noticeable?
I need to replace my clutch and have around £200 budget just for the part, was looking at;
Seat Cordoba 1.8i ( -ch.6KZR002744) Black Diamond Stage 1 Clutch Kit BDC9797PWR Only £196.00
Seat Cordoba 1.8i ( -ch.6KZR002744) Black Diamond Stage 2 Clutch Kit BDC9797KVR Only £255.17
I had hoped to get from VW Heritage but apparently the one they stock will not fit my car (DX code with chassis number of 15Z)
1990 - Cabriolet GTI 1.8 (DX)
rubjonny said
unless you have mega, mega power there is no need. stock sachs kits are fine
Haven't upgraded any of the engine at all, just thought spending a bit more money might help with the quality? The labour cost for swapping clutch out is eye watering… so I only really want to be doing it once
rubjonny said
alrighty I would go std sachs, its what I have in my ABF MK2 with 166bhp and 149 torques
Cheers Jonny as always, this one ok?
http://www.eurocarparts.com/clutch-kit?gclid=CNa6xOzxzMsCFbQV0wodg-UM0Q
http://www.vwspares.co.uk/product_info.php?products_id=2345
ecp often have discount days so could hold out for that
It straight forward on a Mk1 so should be a couple of hours work?
mark1gls said
How much have you been quoted to change over the clutch?
Hi Mark,
Have been quoted £265 ex VAT for labour only…
Euro Car Parts has an easter offer of 20% off on purchases, on top of the clutch being discounted already - making it an exceptionally appealing offer!
But there is very limited information on whether it will fit my car, it just says engine code 'DX' which mine obviously is, but when I looked at BD clutches, I had to check chassis number etc... Is there another way I can be sure I'm ordering the right clutch ?
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/clutch-and-associated-parts/car-transmission/clutch-kit/?641440210&1&7f009da0edd72d835d3e2dd6496b7c173f222d0c&000069
Sachs Clutch KitProduct Code: 641440210
The 16v one is required for MK2 16v and MK3 2.0 8v boxes as they have a larger input shaft
1st thign you should do when doign this job is check the friction disc will slot on the gearbox input shaft spline, if it does happy days carry on with the fitting. If not, you have the wrong kit send it back
Just wish the labour wasn't so damn expensive !! Cheers for your help on this rubjonny
