Better brakes for the golf
(In Topic #200738)
my question is what brakes will fit the mk1 I know Mk2 ones won't fit straight on.
Please help
thanks
rich
I you are not sure post up a picture.
Does the mk2 servo and master cylinder fit straight onto the mk1 studs?
Yes but the steel pen that goes to your break pedal is to short you have to make it longer to fit the MK1.
Note if you use the 22mm master cylinder you probably loose your brake light switch. than you can take this one from the same 16V and mounted under by your brake pedal.
I hope everything make sense ,am just a Dutchman !!!
The 1.8 and GTi are fitted with the VWII callipers as standard.
Picture of callipers with smaller pads as fitted to my Mk1 Scirocco 1.6.
