Alloy wheel help please!
(In Topic #212917)
Offset help
The car is an 87 cabby GTi and the wheel specs are 15" X 8" 4x100 et10. Will these clear the brake calipers and fit under the arches ok? I do have rolled arches which are almost twice the size of the standard ones though!
Any help would be great
what tyres are you going to run, 185.55/ 195/50 205/45?
1983 Volkswagen Golf - Wheel & Tire Sizes, PCD, Offset and Rims specs | Wheel-Size.com
Alloy Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Its good that the second website gives you an image of the difference between the different wheels- helps a lot
The golf is on adjustable coilovers and not running too low so I'm not worried with them. The arches have been rolled which will help with the extra clearance but I don't want to run with really stretched tyres so will probably go with the 195 tyres, by the looks of it they will fit quite well!
