5mm - 10mm hub centric spacers
(In Topic #219934)
what am i looking for?
I could be wrong of course!
What i found helps is the use of some grease on the back of the spacer as this holds it in place whilst the wheel is put on.
One of these also helps
https://www.ebay.co.uk/itm/ALLOY-WHEEL-ALIGNMENT-TOOL-MERCEDES-SLK-2011-FITTING-REMOVAL-NUT-BOLT-1T3/362427916177?fits=Car+Make%3AMercedes-Benz&hash=item5462631f91:g:lPkAAOSwTptbUzL2:rk:4:pf:0
You put it in and it helps hold the spacer and aids in putting the wheel on.
What soecs wheels are you running? I tend to find a 15 or 20mm spacer works best for the back
Ian
I couldnt tell you exact spec wheel off top of my head but its been bit of a nightmare, the guy I bought the car off bought the incorrect alloys and it was cheaper to have arch work done than replace them (my mates a bodyshop guru)
all 4 wheels caught but I liked the stance hence making the decision i did as one rear arch needed work anyways.
just dont wanna buy 15mm and then have the same problem again, however im pretty sure ill get away with 15mm easy
yes JJ
195/45/16 tyres
spoke to the Mrs who is an M&E engineer and she has just had some M12 all thread cut down to 150mm lengths and added a slot in the end
fingers crossed this will allow me to easily use the 5mm spacers i have already!
cheers boys
Made it easier to fit, and the vibration was gone. You might try running to a AfterMarket wheel seller and see if they can get the correct ones for your rims, to make it easier to center.
Oh, my AR alloy's had about 3 different iterations of bolt holes, so they were made to fit a bazillion different rides…(not VW specific.) . The centering rings were about 2 USD each, but made a world of difference.
the alloys area centered its the crappy shims i bought behind them that are a night mare to centralise
what i bought:
https://www.ebay.co.uk/itm/4-X-10mm-SHIMS-UNIVERSAL-ALLOY-WHEELS-SPACERS-FITS-VOLKSWAGEN-4X100/323008662848?hash=item4b34d10d40:g:Sp4AAOSweLBaX2p-:rk:2:pf:0
what i should of:
https://www.ebay.co.uk/itm/10mm-Hubcentric-Spacers-for-Vw-Golf-Mk4-Mk5-Mk6-Mk7-with-CONE-BOLTS/112030787000?hash=item1a158e25b8:g:PawAAOSwmtJXZDnV:rk:1:pf:0
Don't go to long or they will hit the brake shoes in the rear drums….
I have these 5mm ones, not sure if 10mm spacers will work on rear as center spigot is deeper than 10mm.
https://www.ebay.co.uk/itm/VW-AUDI-SKODA-SEAT-VW-MK1-GOLF-GTI-POLO-HUB-CENTRIC-10mm-SPACERS-4X100/253114489744?hash=item3aeecc9b90:g:MW0AAOSwEetV8qql:rk:8:pf:0
