02j - which fly wheel inspection cover with G60 engine?
(In Topic #203371)
When I did my G60 engine conversion I used an 02j gearbox, I purchased the correct metal gasket which sits between the bell housing and engine.
The problem with this gasket is that the flywheel is exposed as there is no cover for the lower portion. I see the 02a gearbox is a 2 piece gasket with a lower section to cover this up.
My question is what can I use to cover the exposed part of the gearbox where the flywheel is visible? Do I have to make something, would an 02a cover work or is there an 02j part?
Rich
Last edit: by Rich.
Mike 16vG60 said
I've got an 02A gearbox on mine and couldn't source an 02a cover plate anywhere. The breakers just chuck them when they remove the gearbox. I've re-used the 020 plate which covers it all fairly well. I think only 2 of the bolt holes lined up with the holes on the gearbox but it is a pretty good fit and nobody sees it!
Cheers Mike, I will see if I can find one. Do you know the part number?
