020 flange seal size
(In Topic #223611)
Passenger side flange seal was dripping oil, so I decided to replace both sides.
I have it all dismantled now, but having doubts about the seal size, as the seals I removed doesn’t seem to be same size.
Drivers side is not as tall as passenger side. I can only read the measurements on the passenger side seal (65/50/10), but drivers side measures around 8mm… difficult to measure as I had to get rough with it, to remove it from the sleeve.
So - what should the size of the seal be?
Transmission is from 1982 according to the stamp, but it’s the newer conical 90mm flanges with a spring installed.
I will give it a try and put it all back together - thanks!
I changed over to fully synthetic gearbox oil when I changed my seals, work's well in cold weather especially the 1st to 2nd gear change.
https://www.eurocarparts.com/p/triple-qx-ep-75w90-transmission-fluid-fully-syn-1-litre-522776022
Good website with all you ever wanted to know/do with the 020 gearbox.
Welcome to BrokeVW.com
I have been reading that site already, I stumbled across it last night - the guy knows his 020 transmission!
I have bought Shell oil with same specs, as it was on sale where I bought the other parts. The old oil was very mucky and looked burned.
I change my gearbox oil every 5 years or 50,000 miles, some on here do it every 4 years or 40,000 miles but I live out in Somerset so not much town/city driving with lots of stop, stating at traffic lights etc for me.
As for me, I used the 75-90 wt in my gear boxes to no ill effect, and just checked the level in mine from time to time… 330K on my 81 Diesel and I only changed the box oil at Clutch time @ 130K.
Now on my autos I have changed it with every swap that I have had to do, but that is for a matter of course.
The only time I have had to change a seal is when the inner CV on a Rebuild by CarDone Broke and well after the first seal change which took well over 4 hours to do because the broken shaft Peaned the end of the shaft to almost weld the clip in place Ruined the inner bearing race..costing me the Transmission, to which I made them refund me for a new tranny….So if your rebuilt over there says CARDONE your car will be Done if you use them….(over here, I got 2 bad Master Cylinders from the same rebuilder a couple of years before, so I should of known….) Only go new for MC's or rebuild your own.
Do you happen to have a mail address for the guy behind BrokeVW? It might be handy to have at some point, and I can't find it on his site.
