WUR replacement/ upgrade.
(In Topic #190170)
engine specs to help are
2.0 tall block
bvh, gs2 cam
audi thottle body with matched inlet
tubular exhast mani + opm stainless system.
wur is currently modded as well
I can't see any advantage in doing it unless the one fitted is not up to the job.
I don't know how many settings the WUR's have is it just a certain temp when cold it richens the mixture then when warms up leans off. put ur foot down dumps some fuel. or is there several temperatures and throttle positions it can vary.
id guess if its just a single temp and throttle position, a more modern system would allow for more fine tuning at different temps loads and throttle positions.
anyone know of one or used one?
also the 16v/audi unit has an extra vacuum connection on the side which will add more fuel on hard throttle
do you know of any non VAG alternatives as I think this is the road he was looking down.
im not after squeezing every last inch of power from the engine. put it 2.0 for extra torque and the other bits were there when I bought it. he saying be able to get it to run smoother lower down.
see if you can find a kstar+fuel setup, fully mappable ignition and fuel for old skool kjet but might want to ask your tuner if he knows anything about them first
