Why Wont My Car Start 30 Minutes After I Have Just Been For A Drive ????
(In Topic #194615)
The car will start fine and you can go for a drive and everything will be spot on how ever if you turn the engine off and leave it for half an hour or so it will not start, it turns over and has a spark but will not start
I don't think its getting any fuel…
If I leave the car then go back to it the following morning it will fire up straight away which is the annoying thing, it only won't start after the engines been running then you leave it for half an hour or so
The fuel pump doesn't prime up every time you turn the ignition on and even when it does prime up it doesn't necessarily start
Has anyone got any ideas as im struggling to figure out what it is??
Thanks in advance
Chairman
Pushing the car was the norm at times - especially when we drove to Germany!
The issue was solved with a secondhand metering head from Funk-Star, £30 (classic vs on the left) and a second hand fuel pump.
Try those and you may be on the right track.
Dan
Fuel filler neck OK?
try this
next time it doesnt do it tap the metering head with a hammer (very lightly) if it then starts it means is a stiking piston in the metering head
this is the fault that dano had but he didnt want to take it apart so just swap it out
Chairman
Find a helpful
friend - or random passerby!! Undo the metering head. Get you friend to crank the engine and at the same time pull up the 'bellow' it should start and you know that the metering head is to blame.
earth lead to the mounting points of the start
then the live on the spade of the solinoid, it should click in and out
if it doesnt then its bad, replace the whole thing
next you can put the live onto the bit of braided wire coming from the solinoid to the motor, the motor should spin, if not the motor is bad,
if the motor is bad it is more that likely you brushes on the comm that are worn earthing out, or the bushes that hold the centre of the coil in place could be worn or not there, this causes the coil and armiture to touch meaning it wont work
everything is avaible to buy from here Wood Auto Home Page
new brushes are about £15, new bushes are a few £ each, a soliniod is around £15 and bit of time and bobs your uncle
some say just buy a news one but where would the fun be in that
Last edit: by rubjonny
There are two cap types, vented and non vented, GTIs must have a non vented one fitted with "ohne blau lüftung" stamped on the metal part.
carby one I assume will have "mit blau lüftung" or similar
