WEBER 34 TLP
(In Topic #194277)
Cheers Marc.
Website Manager
as for the icing up issue, 9 times out of 10 its the warm air feed at fault, make sure the flap inside the airbox actually opens when the car is runnign and the warm air pipe and shroud on the exhaust manifold is all there and hooked up properly. You should also swap the carb heater from the 2e2 over to the weber, but im not sure how much of a difference that makes
