Bike carbs
(In Topic #210837)
I'm sure this has been covered but from all my reading I simply can't quite figure out my issue.
I have a mk1 (with a polo GT 1.3 head/1.4 bottom end) and some GSX bike carbs. I bought the engine with carbs in one unit from another car. I slotted it all in after servicing the carbs and she runs - pretty well too. But start up is very rough and lumpy until a few minutes in tickover settles a bit. Great on full revs but idle is always a bit lumpy and cold/warm start up is like starting a lawn mower.
The manifold is 4 seperate 'top hat' type… no take offs so can't balance the carbs. Is it the balance by the sounds of things? I could tap the 'top hats' and meter/balance… I did relocate the bike pump to next to the tank - was in the bay - which made things marginally better on startup.
Considering sticking a normal carb on - maybe even weber 40s but if it potentially will run smooth i'm happy to keep em so seems a bit drastic. Can carbs be as civalised as a weber?
thanks all,
Tom
Should be a slider at the front
You should be able to balance the carbs by using a vacuum balancer on the trumpet, no need for take offs on the manifold.
Interesting about the pump move.
I have twin 40's on my Derby, that's got a 1272cc in it. Runs nice.
I think they'll always be a bit rough at tickover and low revs tbh. At the end of the day they are desiged to run
Yes the choke hooked up, and essential I might add!
I've not got any trumpets on the carbs - might be an idea! They are just bare carbs atm.
I thought you monitored the pressure within the manifold so between carb and combustion chamber. I know some carbs have a take off where they connect onto a manifold - not these though. Can you simply monitor the 'pull' into the carb..?
Tom
Hope you like my technical imagery
