Problem vacuüm system
(In Topic #199959)
I've got 1500JB (auto transmission)
With a 34tLP weber
How do I connect the vacuum tubes?
It's was already in a shop and that guy really mest up so I need to know how it has to be connected.
The original pierburg 1B3 has more then one connector for vacuum tubes, the weber only has one.
Just did a test ride and it drove pretty good then I stopped on de size because he wanted to quit every time I let go of the throttle.
By adjusting the long screw that was solved and all of a sudden I'm leaking cooling fluid, I immediately shut down the motor and saw that the temperature was really high and my cooling fan didn't do anything..?
Any help is welcome
Thank you!
