Idiot newby with usual problem
(In Topic #199678)
Hi folks
I've gone and got myself a Golf Clipper 1989. It's alright but suffering from the usual fuel neck grot. I've ordered a replacement neck only for it to be too short, which is a ball ache. I thought the Clipper had a shorter neck, so are there 3 sizes of these? Anyway, can someone point me in the right direction for the correct one for my Clipper?
Overflowing swear jar just out of shot:
Ta muchly
Ta muchly
Life Member
Hey Alex, welcome along to the club!
I didn't know there was 3 to be honest! You want to either talk to mark at vw classic, or classic VW, I always forget!
Or rich at crazyquffs, they do stainless ones, although a little bit more expensive
You're best off replacing the gasket as well, if you haven't already got it
Si
Si
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Cheers Si.
I've seen the stainless steel one, it's a bit salty for my budget. Yeah the gasket is borked so I'll be slapping a new one on too. I just don't want to splash out on the wrong one AGAIN. Will check out your suggestions
Life Member
No worries mate, Mark and Richard both know their stuff, they won't steer you wrong
Follow us on:
Follow us on:
Did you order one for a cabriolet or tintop as they do differ?
When you get the right one make sure you paint it before fitting it as the paint on it when you buy it is to stop it rusting when sat on a shelf and no good once under the wheel arch and getting stones, mud and water thrown at it, I painted mine with expoxy mastic, stone chip paint, Hammerite in white to match the colour of my car the a good coat of waxoyl, the Hammerite has mostly chipped off now so I would not recommend just using that stuff.
Life Member
The tin top one is much longer than the cab, and goes at a different angle, I cut about 6" off the tintop one I fitted and bent it to pieces, that was a fun day wasn't it
cavs
Follow us on:
Follow us on:
Any idea what I've got here then. Is it for an early Cabrio or something? It was listed for a Clipper, which is clearly tosh
Life Member
Could be, what engine does yours have Alex?
chortle
you know a lot about cabs, was the earlier a different tank?
@funkstar
crazyquiff
sort this nice fella out with the right part
@funkstar
Follow us on:
Follow us on:
1989 should be the larger fuel tank, 55l, you should have a space saver spare wheel.
Not sure if this is the right one, might be worth a phone call or see and check the part in a store?
http://www.gsfcarparts.com/293vg0130
its also a good idea to change the rubber hose from the filler neck to the fuel tank and 2 new jubilee clips make life easier.
2 sizes again so check it's the right one, gsf website is not great with sizes and info!
FUEL HOSE - FILL NECK TO TANK
I've got a 89 Clipper with 1.8 Carb
Life Member
Think that's the tintop one
mark1gls
- looks much to long
That's what I was getting at as well, you'll have the large tank, couldn't remember the year though
Follow us on:
Follow us on:
Thanks Mark, I assume this is the same but cheap. Maybe I'll buy it to hack up and bodge… er.. adapt carefully
http://www.ebay.co.uk/itm/V-W-GOLF-MK1-1981-1983-PETROL-TANK-FILLER-NECK-NEW-/350532162470
Life Member
If you're gonna bodge it you can have my old one, where you based?
Follow us on:
Follow us on:
You should be able to get one off eBay.
There's is at least two different ones. As I think the early cabby 79/80 had the tin top fitting.
Use the google search box on the top left corner search for filler neck. I'm sure there will be a guide to modding one to fit.
You have a spare? I'm in Kent, where are you?
Life Member
Well I didn't like that I bodged the other one and one happened to come up, I changed it last weekend, I'm Manchester, but in London at the weekend? Probably no good to you haha.
Follow us on:
Follow us on:
The one in your link is for a tin top so it's slightly different.
Perhaps the old one you have taken off is a replacement which has been made to fit before and the new one you have is right and you just need a longer rubber hose to join it to the fuel tank?
As it says in this link it need modding to fit.
http://www.ebay.co.uk/itm/FUEL-TANK-FILLER-NECK-NEW-FOR-VW-MK1-GOLF-CABRIOLET-171201129F-/391218806246?fits=Model%3AGolf&hash=item5b16753de6
this one is shorter.
http://www.ebay.co.uk/itm/V-W-GOLF-MK1-1974-1991-FUEL-TANK-FILLER-NECK-FOR-CABRIOLET-NEW-/351475270282?fits=Model%3AGolf&hash=item51d58f028a
in the first picture of your filler necks the new one is a shorter one but the one taken off the car is longer??
Ah, yeah Manchester/London not convenient for me. Cheers anyway.
Interesting shout about the rubber hose being chopped… but the angle's wrong
I have a 1988 car and can get a picture of mine if any use, I know it's the same filler neck as fitted buy VW as I replaced like for like and I owned the car for 21 years so it's was not very old when I got it, I won't be able to get a picture till Friday night as its in my rented garage up the road with out an engine in at the moment!
