Tickover adjustment Weber conversion
(In Topic #216666)
T
Last edit: by TBigJohn
Have a look here for where the idle screw is, I run my carb car at 950rpm as found 850 to low and things start to rattle at that speed and if you turn on lights, blower, heated window it drops even further.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-carb-engines_2%2Fidle-adjustment-1-8
I would just try it out, count or mark where the idle screw is now so you can adjust it back if it goes pair shaped.
Get the car nice and warm before adjusting any thing and after moving the idle screw give the car a good couple of blips on the throttle so it settles.
