Squealing noise
(In Topic #215409)
Last edit: by Mk1dcky
I've discovered what the problem is.
The plunger is stuck in on the metering head and filled all the cylinders with fuel.
Does anybody know how to free the plunger?
Managed to get the plunger free but still won't work properly.
Going to try a different fuel distributor on the metering head. Can understand why there is so many different ones, do you know if they are interchangeable or what the differences are?
Andrew
I had a 1.6 FD fitted to my 1.8 but it wouldn't run right and I was told they weren't interchangeable as the 1.6 engine had a different power curve so the metering head was set up differently. I was also told that the WUR was different as it matched the different FD's. It will start and run though, it just might not run properly.
main thing is check the part number on your metering head and WUR, then we can advise moving forward
The problem is the car has had a full nut and bolt rebuild and it won't start. All the valve timings correct, ignition timings correct, good spark, fuel pressure tested up to metering head all good. Now tried a different fuel distributing head on, appears to be working but still no go.
So running out of ideas?
I hope this helps, let us know how you get on.
I think the problem could be the fuel injectors, took them out last night and the seals are rock hard and the injectors don't look promising, will try them over the weekend and get new seals.
This is how it's looking so far.
Hoping to get it finished just after Christmas
Good luck with getting it finished for Christmas, keep us posted on progress as I look forward to seeing that car running!
The injectors don't look great. Did you see if they were spraying fuel and did you have fuel in the injector pipes when you removed them? One thing I did forget to mention, when I was setting mine up after it had been standing for over 7 years I removed the injectors and had the fuel pump running continuously. I then adjusted the mixer screw until the injectors just started to squirt fuel and then I backed it off until they just about stopped. When I tried to start the care it fired up almost immediatly. I bought my injectors off eBay from a seller called tierod69 but Classic-VW do brass ones for £25 each, a good price!
Cleaned the injectors, put new seals on, and eventually she fired up.
Sounds good but won't tick over at the moment, but now it's running I should be able to get it to the Vw centre to get tuned.
The problem is getting it up and down the drive as the drive is very steep and awkward to do when it's not running.
Yes I did the restro myself apart from the painting, but still a bit to do on if yet, still no seats in the front and few other jobs to do.
Needs to go back to the body shop for flat and polish as well.
So I took the other mk1 out for a 200 miles blast at the weekend to celebrate.
Here's a pic so you can see how steep the drive is
