Pressure test kit
(In Topic #232529)
Will get some swagelock fittings etc but mainly its the specifics of the gauge as its using fuel instead of air etc.
Any info will be appreciated.
I have made a gauge for pressure on my Digi, using a gauge that I had laying about for a/c use it worked well when I got it plumbed in.
If you are talking about compression then you need one that is about 150 for gassers, and 500 for diesels. I have both.
here is a quick snap, 37 bucks us. Amazon/Ebay…
https://www.ebay.co.uk/itm/Universal-Fuel-Injection-Gauge-Pressure-Tester-Test-Kit-Car-System-Pump-Tool-Set/391796522684?epid=14031285550&_trkparms=ispr%3D1&hash=item5b38e47ebc:g:hGgAAOSwPh5ZFSqe&amdata=enc%3AAQAFAAACgBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkyMJZWL%252BqFSgQ3TOOe%252FNr7kiDcgGujzYNd5ecYT%252BtHaiD3AhMWugBLo2psmteXlHueqVJJif6FmUI7Vk6Kot1ra42HzQEzVLTp%252FdzF%252BlRTdwzADLZHUWP%252F1f5mBQWv3cUTutEHQWze4cWaZU5xoUoDVAm9BMiu5%252FKcPZDdLnN%252Fz4yXS0%252FRNQegRTklBlkqhnW4zeQylqDPgI63mQtelVk4t5SjnendOcawj%252Ba6R6eifmekY%252FyUd0SHEOpJ7s8XNdvl9mSCyD3Lg%252Fc5aCg8NZkfqQSADqfNW65kD5zvxMX9fds6ILoFnq4NLlY3lLYD2FuFzUZ9Rr0DBlDuk0sCdmHDhYMeNha8Bu2UQlpgVYHjoG5UbmhMhbpJeWXoA94UqAOCK3GBiY8pWlOt45K2pchYQ1TxRIQbG0dfOSY5SvbPFz6ML8YLDId50dSgr4Zo8pL5sev8qEUNqXT%252FgisYOXfAgWrihaVSLTO3pmi0k0dUIXAZGducjYz1wLRGo5cjhhcW9mSC0ATKaiEraX24%252BHHIkQ039BPMAVeJdjG1XhhOmdmnXHZkV4QmwzkLg3fw7veYpKem5MLkF6j%252B6Q643yIIWrWmDfkK8QoALoyzn4V6yzBATkCtkZG0S6%252BuiCv0wn6LHUezfe2GE7qLw2lvvix9MgG%252Bbw6U3uWjHvQh9t6LkVwbs%252BsyvzrYAs%252BnbtrQVRHnqeNgvjxYF0AkwvEYaVm1twCt%252BPlZ8FMlxSuuYsvaOLrM5FA8miRnZNLw%252B%252F2Q6rKdToL0cmeDgNiZgLJRTSPh09%252B2sCZVrSFFt6dU317DKs%253D%7Ccksum%3A3917965226847b2407a55ebe42a793e3b660106c36b8%7Campid%3APL_CLK%7Cclp%3A2334524
Last edit: by Briano1234
The only bits i didnt have available were the 1/4'" NPT male and female unions for on the distributor and the WUR line. Im fitting them to some 6mm plastic pipe hopefully but havent found anything easily available on the net yet.
Only confusion i have is that i read they were M12x1.5, but also 1/4" NTP. Same exact size?
Only issue is then i have to replace the pipe ive made up and get a fuel hose with a banjo bolt on it and then id still need a union to connect to the distributor from my 6mm pipe
I read that its metric bolts (M12x1.5) with imperial pipe fittings 1/4 NTP which is why its an absolute pain. If this fitting for 6mm tubing work then i will post it back here and share it.
