pierburg carb heater
(In Topic #193076)
http://www.clubgti.com/showthread.php?144497
keep em peeled and post up wanteds on various forums im sure you'll find someone with a goodun eventually
My problem is I have a k&n pan filter and I also have a g60 rocker cover fitted too so I can't fit the standard air filter setup back on so was in a bit of a corner lol!
So hopefully this will help me out with the icing, will be better than I have now anyway so there will be some improvement at least
If anyone needs the part number it's 026 906 333
My carb does ice up but only if I use too much throttle so I just drive it carefully and I always leave the car til it gets up to temp before driving it as to get a bit of hot air in the engine bay! Is there not a smaller air box I could use like one off a polo or something then use the warm air flap assembly from the golf air box?
