Misfire
(In Topic #212367)
perplexed
Anyone with these symptoms in the past or pointers to a cure would be most helpful.
I'm guessing members are busy with holidays etc…
Is the misfire consistent, can you replicate it or is it random?
Second I would suspect the smell of fuel is because the timing isn't right or that your HV leads are suspect….
Mis-fires are usually electrical in nature and not Fuelish.
Plugs wires Cap rotor, or clean the corrosion off the rotor and cap.
Bad Earths are the bane of these critters as well as vacuum leaks….
But 5 years and you haven't replace the Cap, Wires, Rotor, and or Plugs? it's time.
The 5th injector only fires up for a few seconds when the engine is very cold eg cold weather outside so I don't recon it should be firing with the weather we have been having.
The earth wires I will look at but I did service those a couple of years back.The misfire only SEEMS to be at low revs.I am using SHELL expensive stuff 98 oct?.During the week I took out all the injectors but No.2 had what looked like rust at the top wherre it connects to the line….all the rest were 'clean'.I have put them all in a little jar & filled it with carb cleaner.. who knows it may work.So I will cocentrate on those before anything else is tried.gonna try and eliminate that first.Will update you over the W/end..Thank you all.
There is a couple of types of injectors, if you have a rubber air hose going to the back of the head between cylinders 3 and 4 then you have the later air shroud injectors but you can fit early type with a bit of modding.
let us now how you get on and check the timing, if the cambelt has been changed and the misfire started check the static timing marks.
Take the fuel pump relay out and No 17 below, turn 17 around till it fits where the fuel pump relay lives and the fuel pump will run when the ignition is on and engine not running.
Flawndooley said
Thank you for your advice squire..I had already disconnected the correct wires on the coil & had the injectors ready in some bottles.Then the rain came…I dont play with sparks & fuel inside my garage anymore.Over 5 yrs ago my MK1 mex burnt out my garage and 20% of my house….
OUCH.
Removing the plugs told me that one wasn't firing.
Went and got another set, this time it was worse.
2 plugs weren't firing.
Daughter got home and I swapped cap wire and plugs between my 2 cars and presto it was working.
Put on the original cap and wires misfire. Unplugged one at a time and found the bad wire.
Put the new wires on and all was still good.
Took the 2 sets of Bosch back and got NGK plats and it loved them…….
So don't discount a bad plug or wire, or both.
Slight exaggeration but if the car doesn't run don't start by ripping out the back axle! 😂
50% of the time it's something basic but finding it is an art. 👍🏼
But we're all guilty of it at one time or other! 😉😂
