Metering Head Part Numbers
(In Topic #245424)
Whats the difference between 1.6 and 1.8?
Bosch 0 438 120 189
VW 049 133 353 AA
When I search those part numbers the most helpful information I find is the same units listed on Ebay as for a Mk1 1.8.
The second I bought from an EG car being broken, and its part numbers are:
Bosch 0 438 120 035
VW 049 133 353J
When I search those I seem to find Mk2 1.8 units.
Now I know these are the part numbers off the air flow meter section, and that the fuel distributor section has a seperate part number, but I'm assuming they have been swapped as a pair like they usually do.
Looking on VAGCAT I have found the part number 049 133 471 D which is for a 1980 EG GTi
So unless the above is wrong, I have the incorrect metering heads, my car has run from the AA head for the past 10 years without issues, although I assume it would over fuel.
Was intending to rebuild one of the metering heads to chase a stutter but would rather start with a unit for a 1.6. What is the technical internal difference between the 1.6 and 1.8 metering heads?
Regional Host NE
Key Internal Differences Affecting Flow Rate
1. Fuel Distributor Plunger
- Yes, the plunger is different between 1.6 and 1.8 units.
- The plunger diameter and the shape/profile of its metering slits are tailored to control how much fuel is metered for a given flap position.
- 1.8 units have plungers designed for higher fuel flow, meaning larger or differently shaped metering slots and sometimes a slightly larger plunger diameter.
- This affects how quickly the plunger moves within the fuel distributor to allow fuel flow.
- Underneath the calibration screws (sometimes called control valves or flow valves), the valves themselves are different sizes or shapes.
- These valves limit maximum fuel flow and fine-tune the characteristic curve.
- For example, the valve orifice diameter in a 1.8 unit is often larger to allow greater fuel volume, while the 1.6 valve orifice is smaller for reduced flow.
- These valves also influence how much fuel flows at idle and part throttle.
- The shape and weight of the airflow flap and plate affect how the fuel distributor plunger moves — heavier or differently balanced flaps in the 1.8 unit cause different mechanical responses to airflow.
- However, this mostly affects sensitivity and is secondary to the actual fuel flow control inside the distributor.
- Inside the fuel distributor, metering slits/slots in the plunger and distributor body differ in size and shape to control flow rate.
- These slits are precision-machined to calibrate the system to the engine’s displacement.
Plunger Diameter | Smaller, narrower metering slits | Slightly larger, wider metering slits |
Calibration Valves | Smaller orifice valves under screws | Larger orifice valves for higher flow |
Airflow Flap | Lighter, smaller flap for less air flow | Larger flap, tuned for more air flow |
Metering Slots | Narrower slots for reduced flow | Wider slots for increased flow |
- The combination of plunger and valve sizes controls the max fuel flow and fuel curve shape.
- If you fit a 1.8 metering head on a 1.6 engine, the metering head allows too much fuel for the given airflow, causing a rich mixture.
- Conversely, a 1.6 metering head on a 1.8 would starve the engine of fuel and cause lean running or hesitation.
More Info:
