Mechanical Fuel Pump failure
(In Topic #234944)
Only installed it last August but it`s failed.
It was a Meyles pump from VhHeritage on my 1990 1.8 Carburettor (Karman Clipper).
Is it just bad luck or should i look for a better quality pump?
Any recommendations?
Thanks.
Any branded new part should last longer than 7 months…
Early-1800 said
Have you got the dreaded rotten fuel filler pipe and crraapp in the tank either blocking the fuel lines and/or over working the pump into an early death?
Hi there,
Yes fuel tank removed, checked, cleaned and re-fitted. Fuel lines replaced right up to fuel pump.
If i suck the fuel lines, i`m getting a nice big delicious mouthful of expensive unleaded.
Fuel filters spotlessly clean etc.
Maybe i just got unlucky.
Very little more expensive but i`m happy to see how it goes.
