late cabriolet lift pump replacement strainer?
(In Topic #189827)
Hi guys,
I have a late cabriolet lift pump but noticed the strainer doesn't look very clever and has a hole in it. Can you buy the strainer separately? I have a vdo pump, part number 357906092c.
Rich
Rich
Do I just need to replace the whole pump as this is not available separately?
Have you tried calling a VW dealer?
The last lift pump I bought did not have a filter on the end so had to reuse my old one so just make sure if you do have to buy a complete pump that it does come with the filter.
this is a 19mm pump, the 19mm strainer is part number 867906098 and available from VW at 13+VAT
thanks John and thanks for the sender help
