k-jet pressure test kit
(In Topic #203512)
I need to run the pressure tests on my Cabby GTI to chase down a fuelling issue My mechanic friend doesn't have the right test kit, so looking to buy my own. The Sealey and S-P kit is serious money. I have found these which claim to be suitable for k-jet:
http://www.ebay.co.uk/itm/70pc-FUEL-INJECTION-INJECTOR-PRESSURE-TEST-tester-TOOL-KIT-master-GAUGE-UK-/311569728181?hash=item488b00c2b5:g:4wwAAOSwHgVW68wN
http://www.ebay.co.uk/itm/bNEW-Fuel-Injection-Pressure-Test-System-Kit-Testing-Compression-Car-Tool-Set-/371492727672?hash=item567eb12b78:g:vsAAAOSw7FRWUsbt
Anyone got any experience of either of these, or can recommend an alternative that won't break the bank?
Lee
2001 Zafira 1.8
2001 Zafira 1.8
SG Tool Aid 33865 CIS K-Jet F.I Tester w/ Case | JB Tools
which looks a bit more specific and seems to get more online mentions on US forums for k-jet vehicles (VW, MB, Porsche, etc).
2001 Zafira 1.8
2001 Zafira 1.8
Amazon.com: CTA Tools 3420 Fuel Injection Tester - Bosch : Automotive
2001 Zafira 1.8
2001 Zafira 1.8
If you pull the WUR line off your car and take to a local hydraulics fitting place they'll be able to join the kit together for you.
or something like this:
http://www.ebay.co.uk/itm/121939260089
thanks for that. I wasn't sure about the ebay all purpose kits, but will give one a go. It is frustrating that the purpose made k-jet kits only seem to be available in the states - and they want $100 for shipping and customs on top of the price of the kit, and a 4 week wait. Funny you mention a local hydraulics place, as I visited one yesterday - they mostly do motorsport - and today they quoted me £170 for a kit to be made up. I know Crazy Quiffs used to import a kit, and from what I found online, they looked like the JC Whitney kit, which is NLA. There was also a Porsche 928 specialist who used to supply them, but gave up as supply from the factory became too erratic. Given there are so many cars still around that use k-jet, who would think they would be so hard to get!
Lee
2001 Zafira 1.8
2001 Zafira 1.8
Its a "TU-14C Basic Bosch CIS Fuel Injection Tester", Made in USA.
i just put a bid on an ebay one before I saw your post! But would still be interested - how much do you want for it, including postage to London?
Lee
2001 Zafira 1.8
2001 Zafira 1.8
2001 Zafira 1.8
2001 Zafira 1.8
Verstuurd vanaf mijn SM-G935F met Tapatalk
I believe you asked Mars Red LA2A?
Mars Red it is !
Mars Red it is !
Has anyone bought a kit off ebay (there seem to be plenty)and if so, which one?
Looking at most of them, I can't see how they would connect into the fuel system as they talk about shraeder connections (which k-jet isn't) or they look like push fit rubber hoses and jubilee clips which I'm not convinced would work with the pressure. (I remember years ago trying to replace a pipe to the fuel pump with rubber and jubilee clips - went everywhere!!)
TIA.
J
2001 Zafira 1.8
2001 Zafira 1.8
I had a NOS VW pressure gauge set and the rubber rotted away with age, I just replaced it with fresh hose + clips and no leaks
had to do the same on my main pump as one of the new hoses made up by a pipe specialist again split at one end (i suspect poor quality or incorrect rubber hose used) so I had to cut off the ferule to get to the barbed fitting underneath, again new fuel hose and proper clip then it was fine for the couple months I needed it to last for
ideally gauge needs to be rated for fuel, but for the limited use its going to have it shouldnt be a problem. I would at least rise the gauge out with water so its not sat for any length of time with fuel in. obviously make sure its fully dry before you use it again
