K-jet fuel pressures too high
Trying to set up the fuel pressures on my 1982 DX GTI, but I'm getting nowhere with it.
The system pressure is reading 9 bar, autodata says it should be 4.7 - 5.4 bar and I've tried removing the shims from the spring to lower the pressure but nothing's changed, I still need to set the hot and cold WUR pressures as I have the  Audi WUR mod also. I've check the routing of the pressure gauge and I'm pretty sure that''s right.
Should I have the WUR wiring plugged in and the vac line on it or not?
Should also mention that everything is either new or refurbished and that the car struggles to accelerate as if its missing but suspecting this to be a fuelling issue.
Does anyone have any ideas what I should do as I really want to make the AGM this year!
I thought with the WUR mod the pressure was adjusted by the allen key in the back of the WUR
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
swb transporter 6.1 Highline 150
I was told the allen key on the back is to adjust the hot pressure and the round pin on the front of the WUR adjusts the cold pressure but the system pressure is on the fuel metering head?
So confused with it all now!
Have a search for member rubjonny
Look on his signature he has everything you need for kjet
Ok, I'll have a look cheers!
Update for anyone with the same problem-
Turned out to be a blockage on the return line, I had sealed the fuel tank with Por15 fuel tank sealer and the end of the return pipe in the tank was slightly blocked, managed to clear it with some thin wire. The gauge now reads 5.2 bar of system pressure.
