GTi Swirl pot issues....>!
(In Topic #208891)
I assume the fuel system will still work okay without the flap…….
Keep the tank 1/4+ full or take it easy on big roundabouts.
My current thinking is to keep my tank in situ and add an inline fuel filter between the tank and the fuel pump. The in-tank filter is obviously no longer doing anything as the swirl tank is no longer sealed at the bottom.
I never noticed any fuel starvation due to the "leaking swirl pot" - and as crazyquiff has previously mentioned the fuel accumulator SHOULD maintain enough fuel to "get you round the corner".
Looking into the tank with an endoscope it would be pretty impossible to re-seal the base of the swirl pot.
Not only access. The problem is that the fuel outlet tube runs along the base of the tank to inside the base of the swirl pot and then has a 90 degree end facing down towards the bottom of the tank. I have confirmed this with a piece of wire directed along the pipe.
Therefore the seal on the base of the swirl pot must have been of a greater diameter than hole in the base of the swirl-pot - if that makes sense……..?!
I have read various "theories" about the "rubber" base of the swirl pot - from it being an o-ring, a one way flap, permeable…….
The thing that mystifies me is how does the fuel get into the swirl pot??? If it came in the top only then when the fuel level was below that of the top of the swirl pot - no fuel could enter the swirl pot???
Interesting…………………………
Having read on the forums about the missing swirl pot rubber base it seems some people say that leads to fuel starvation. I wanted to make sure that before I put the tank back it was not going to cause any future issues.
as an experiment to see how well it can help once pump is sucking air, pull the fuel relay out when its idling and see how long it keeps running for
iirc there might be seals in the side of the pot too which would be more of an issue? plus it would depend how full the tank is as well, the length of the bend and which way you are cornering
Regards Volkswarren
Regards Volkswarren
Facebook would have you believe these parts are now available to order via vw dealerships too
Regards Volkswarren
