Gti jetronic issues
(In Topic #209718)
Help needed
Gti jetronic issues
Gti jetronic issues
Sent from my iPad using Tapatalk
On the drive
Myvalver 89 GTi Grey mk2 16v
On the drive
If I have fuel getting as far as in metering inlet but none coming out of the banjo bolts on top does it suggest that the metering head is blocked?
see whom get the issue fixed first.
On the drive
have you got the main pump relay/socket jumped while you're doing this test? if not look for the fuel relay and bridge the 2 terminals on the socket where pins 30 and 87 go with a loop of wire, if oyu can pop a switch inline with it that's even better as you can then trigger the pump at will.
If it had the later fusebox I would say pop a 17/18/100 relay in the fuel pump socket then it'll come on with ignition on, but this doesn't work on the older ceramic fusebox cars the terminals are too big to fit. a 53 relay might work instead but not got an old fuel relay to hand to check the terminal layout!
this thread is worth a look:
View topic: Fuel Tank cleaning *HowTo* clear that blockage - The Mk1 Golf Owners Club
also as briano says they were originally fitted with a filtered banjo bolt on the inlet side of the metering head, apparently at one of the service intervals this was supposed to be removed but it doesnt always happen. If you can find a spare return banjo bolt its the same size and no filter for a quick check.
The pressure regulator seals can fail too, this results in lower pressure I believe so thats worth a check, plus look for any fuel leaks. only way to be sure what the system pressure is though is to fit a set of pressure gauges, not the kind of thing an average DIYer has sat around but they can be bought/made relatively easy
