GTI Flexible Fuel Line advice
(In Topic #219789)
I am quite keen on fitting a flexible fuel line kit. I see others have made up their own plastic/rubber fuel pipes to replace the rigid - but I dont really want to make my own.
These seem good but very pricey!
https://www.classic-vw.co.uk/mk1-golf-gti-flexible-fuel-line-kit-83-171201361b--171201217d-12895-p.asp
Has anyone used these and how did you find them.
I note they are Teflon so OK with modern fuels.
Will they fit in to the original clips/rubbers under the car?
Do they "lie" quite straight or end up rather wobbly compared to the rigid pipe.
Any thoughts gratefully received.
straightness will depend how much care you put into the install, theres plenty clips under there to hold it tight so you can get a decent result. getting steel lines straight would be a different kind of chore thats for sure
I assume the new steel lines dont come pre-shaped!!
