Golf clipper cabrio cutting out when warm
(In Topic #197992)
I think it might be carb icing please can someone help as I'm losing the will!!
Also tank has been cleaned out and breather pipe from sender has been checked and it's clear
If your car is cutting out while waggling the keys the ignition switch may be worn and need replacing. (threads on this site about this)
If your car has a webber carb you could try restricting the fuel return as you can get problems with to much fuel being returned to the fuel tank and not enough getting to the engine. You can try to remove the fuel return pipe and cap it off as you don't want fuel pumping out onto a hot exhaust manifold! see if that is better then restrict the fuel line with a welding tip or similar.
There is a few threads on both of theses problems.
Carb rubber mounting plate splitting letting in air, Wobble carb to see if idle increases/decreases?
http://www.clubgti.com/showthread.php?144497
also a good idea to use fuel hose jubilee clips as the standard ones can squash just one side of the pipe and can cause a leak and you don't want fuel leaking any where near a hot exhaust manifold or you may have a big BBQ!
